cpvc cemented joint
Old 08-14-20, 05:12 PM
C
cpvc cemented joint
Connecting a CPVC coupler to an old 1/2 inch CPVC pipe in a tight space earlier, did not push the CPVC pipe all the way into the coupler before the cement hardened. Turned on the water, no leak. But still kind of worried, what are the chances that the joint will suddenly break in the future?
Old 08-14-20, 05:21 PM
Received 4,090 Upvotes on 3,673 Posts
Was it fresh glue ?
PVC glues work by melting the PVC together.
If it was older/weaker glue.... I'd question it.
Old 08-14-20, 05:39 PM
C
the glue is fresh, the cpvc pipe is old, the coupler is new, did not push all the way in, no leak right now, wondering the chance that the joint will break in the future. It is behind the wall, that's why the worry.
Old 08-14-20, 09:31 PM
If there's any question.... it needs to be replaced. Too risky to bury it.
Old 08-15-20, 02:20 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
The depth of the joint is there to ensure that enough material chemical melted, and bonded, to ensure a strong joint, If the pipe was not fully seated, you have a comprimised joint that is currently sealed but weak!
How well do you want to sleep?
Old 08-15-20, 02:33 AM
Received 869 Upvotes on 760 Posts
I had a similar scenario between my bath rm and the water heater closet. I left that portion of the wall open for a few yrs until I finally remodeled the bath rm 2 yrs ago. I've not had any leak. Had it been more accessible I would have cut it out and redone it. So far so good.
How far did the pipe get pushed into the fitting?
