No spark in hot water heater
Old 09-19-20, 06:52 PM
T
Good day. New to the forum.
my water heater pilot stopped working and now the pilot won’t light. No spark in the ignitor when i look in the little window but there is a spark from ignitor switch to connector. I think the thermal switch is broke and therefore keeping me from getting gas and a spark. Anyway i can test this? The thermal
switch button just sits there and doesn’t spring back when pushed. The heater is an AOsmith with a honeywell control panel
Old 09-19-20, 07:14 PM
Received 4,119 Upvotes on 3,699 Posts
Welcome to the forums.
Thread moved to water heater forum.
How old is the water heater ?
Post the full model number off of it.
Old 09-19-20, 08:37 PM
T
Thank you.
The water heater is a AO Smith HCV 40 300. I believe it is 9 years old as the date on the label says 2011.
i think i need to change the burner assembly coz when i took it off, i couldn’t get a spark in the igniter when it is connected. The igniter itself when out of the control panel sparks fine but when connected it does not spark at all.
Old 09-19-20, 09:13 PM
Make sure the thermocouple nut is snug on the bottom of the gas valve.
That's not a complete model number.
There may be a TCO protector in the system that is open.
Old 10-05-20, 10:01 AM
A
Received 288 Upvotes on 263 Posts
Looks to me that there is something wrong with the ignitor if you do not see a spark in the little window but you do see a spark someplace else when you press the ignitor button.
Also the ignitor and the button need to make a clean firm contact with the other metal parts where they are snapped or pressed or screwed into place
