rusty things appearing on top of the hot water heater
HELP !
weird rusty things are appearing on top of my hot water heater, anyone know what they are and does this mean something bad is happening to the hot water heater ? What do I do ?
I would have your exhaust flue inspected. It does not appear to meet code or the manufacturers requirements. Every one I've seen requires vertical piping of the flue before any bend. Yours has the 90° directly connected to the draft hood. And, there is a limit as to how much horizontal run you can have in relation to vertical. All your photo shows is horizontal so I hope there is a good bit of vertical flue outside.
You still need to incline that horizontal flue going to the chimney. Is that water heater a tall boy or a short boy. Could be why the flue is so flat if the pervious tank was a short boy.
As Pete mentioned it could corrosion from flue if it was only there but I'm seeing corrosion or rust above the AO SMITH sticker at the coner and around the hot or cold pipe. My guess is you may be starting to get a tank leak if you haven't already. The tank may be leaking and soaking the insulation, still too small to really notice but it will not mprove with age.
If you can lift that top cover off a little and feel your insulation if it is wet you may be able to avoid an emergency . Sometime to can hear what sounds like little droplets of water hitting the burner box for lack of a better name.
Spott,
right on, I was just doing a close look at it, the water heater came on, and I saw water coming out where the flue and the top cover meets, is this serviceable, or does that mean this water heater is dead and I would need to replace it ?
Hate to be the bearer of bad news but replacement is the way to go. The good news is you caught it before it completely let go and flooded the basement.
When thru that last summer. Water logged insulation made extremely heavy old 50 gallon oil fired tank (180 pounds shipping weight) . Had to use cum-a-long to pull it up basement stairs.
I did some work on Bradford White MITW40L6BN gas water heater for my friend. After I had left, he found a small rectangular piece of insulation near the unit. It probably fall out when I removed a cover to access reset button/thermostat. I didn't notice it at the time and didn't put it back.
He is afraid to reinstall it himself and I don't feel like driving back to his house right away just to reinstall a piece of insulation.
I wonder if the heater will work less efficiently and/or the cover will get hot enough to burn someone without this piece?
