help!! corroded water heater nipple
my water heater is jusr over a year old but is very corroded on the cold side…. what can i do to fix and prevent this
A year.....
You're going to have to cut the copper pipe above the fitting and carefully remove it.
Since the fitting is brass it should come apart.
You'll need a good pair of Channel Lock pliers.
Is that tank just "hanging out" there in free air ?
On another note, they make flex flue pipes but that's not one, I'd be a bit more concerned about that.
CasualJoe
voted this post useful.
That appears to be a piece of dryer vent, flex exhaust pipes have fittings on the ends to make them gas tight not duct/metal tape.
Just and observation, make sure you have a CO alarm in the area.
ok that is concerning… i do have a co detector tho… im surprise none of the plumbers ever mentioned that… and i had a few from big companys to plumbers i know… it was like that when i got the house… i plan on selling it soon but as far as this corrosion what should i do
The blue expansion tank should be tethered to the joists above perhaps using some cloth or leather straps. Otherwise, if it should fail in a certain way (air leak at the far end) it could fill with water, become too heavy, and snap/break/crack off resulting in a huge flood.
If you are lucky the nipple has not rusted so badly that it breaks in the middle as you try to unscrew it from the water heater.
