Water heater outflow blockage to kitchen faucet only
Old 10-01-22, 11:17 AM
B
Old water heater had low HOT flow to kitchen faucet but newly installed water heater has NO hot flow to kitchen; flow is OK to bathroom. At T-joint, pipe to kitchen faucet is cool while other pipe is hot, so blockage is suspected at joint or along line to faucet.
Is there a sediment SCREEN possibly involved?
How would I safely uncouple this T-joint to inspect it for mineral or sediment buildup?
If blockage is found and removed, can this old THREADED T-joint be reused?
T-joint showing copper pipe going to kitchen faucet. Is this a compression fitting? Can it easily be uncoupled, inspected for blockage. and reused?
Old 10-01-22, 11:41 AM
Received 3,881 Upvotes on 3,478 Posts
Welcome to the forums from Europe.
That looks like a pressure reducing valve usually found on a boiler.
There wouldn't be a screen in it.
Not sure why it would be feeding a kitchen sink.
The arrow is pointing to what looks like a compression fitting and can be taken apart
and reassembled with no problems.
Typically the hot water line coming out of a water heater feeds all faucets.
One faucet would not be piped or treated differently.
Your kitchen sink may have a defective/clogged hot water cartridge depending on the faucet.
Your plumbing may not be done the same as ours here in the States.
