Not enough hot water
Old 11-27-22, 07:38 AM
K
Received 1 Upvote on 1 Post
Moved into a used home we just bought and it has a simple Jacuzzi tub. The house is all electric and one I tried to fill the tub with hot water it did not even come to the first jet nozzle in the tub before I ran out of hot water. I let the hot water recycle but even then the water was not very hot.
I pulled the insulation up on the side of the hot water eater And it appeared the thermostat is set at 125° which is the maximum setting. In the past I have run my gas hot water heaters much hotter.
Without peeling the insulation off the tank I cannot see what size tank this is but it is fairly large.
Might be a stupid question, but can the thermostat in the hot water heater simply be replaced with one of higher value? I would like to use the tub but I would also like to have hotter water in the showers.
Old 11-27-22, 04:21 PM
Received 3,332 Upvotes on 2,991 Posts
The gallonage is in the model number.
Most electric water heaters have dual thermostat that go up to 150°f.
CasualJoe voted this post useful.
Old 11-27-22, 01:18 PM
Marq1's Avatar
Received 1,058 Upvotes on 960 Posts
Most electric water heaters have 2 elements, top and bottom, one could be out, simple check with multi meter!
Old 11-27-22, 04:32 PM
Received 1,182 Upvotes on 1,140 Posts
Welcome to the downside of large tubs - you need huge water heaters to use them.
That said, if your heater is running out of hot water prematurely, this is a sign the lower element may not be working,
Old 11-28-22, 03:33 PM
K
The plumber plumber found the lower element set at 90 degrees and moved it up, said that should fix the problem all but volume for the tub.
Old 11-28-22, 05:19 PM
CasualJoe's Avatar
Received 172 Upvotes on 155 Posts
If that doesn't fix your problem look at the thermostat pictures PJmaz posted in post #3. Those thermostats from Therm-O-Disc have settings up to 150 degrees. I'm sure you can find them at either Home Depot or Lowes.
