Cold & hot lines are connected on water heater
Old 05-25-24, 11:03 AM
B
Received 6 Upvotes on 6 Posts
I came across the setup below while reading this article here. What's the point of the crossfeed looking tube here between hot & cold lines?
Old 05-25-24, 11:21 AM
C
Received 176 Upvotes on 144 Posts
It's a tempering valve setup. It allows you to set the water heater to a higher temperature and then mixes in cold water so the water distributed is a safe temperature, say 120 degrees. Two main advantages of this. First, running the water heater above 130 degrees prevents legionnaires disease. Second, you extend the amount of usable hot water a little, since making a gallon of 120 degree water uses less than a gallon of 140 degree water.
Current codes in many areas now require tempering valves.
Old 05-26-24, 11:47 AM
Received 4,111 Upvotes on 3,692 Posts
A added some visual references to your picture.
This is predominantly used on an electric water heater with slow recovery.
