No hot water on 1st floor. Plenty on 2nd floor
Old 01-31-04, 01:06 PM
carlosee
Question No hot water on 1st floor. Plenty on 2nd floor
The outside temperature today is 2degrees. I live in a townhome. It is not an end unit and I do not have a basement. My problem is that I don't have water flow on the first floor with the hot faucet open. Upstairs is not a problem.
Is there a frozen pipe some where?
Old 01-31-04, 01:25 PM
Ed Imeduc's Avatar
There sure can be ED
Old 01-31-04, 02:46 PM
Mike Swearingen's Avatar
Cool
Probably in an outside wall.
Old 01-31-04, 02:51 PM
Ed Imeduc's Avatar
I have found that when it get that cold .Like if the kitchen sink is on the out side wall keep the cabinet doors open all the time there.
ED
Old 02-02-04, 04:45 PM
carlosee
Talking Problem identified.
I found the source. The hot water heater is located in the garage. I put a space heater in front of it and in about 15 to 20 minutes, I got hot water flowing as normal. I will look into better insulating the shack with the water heater.
Thank you all for your quick responses.
Old 02-03-04, 10:23 PM
pagerboy
Re: Problem identified.
Originally posted by carlosee
...hot water heater ...
Hot water tank? Why heat hot water!
Old 02-04-04, 11:24 AM
Ed Imeduc's Avatar
Have to heat a hot water tank????Id look at the hot water pipes. How about a heat tape around the pipe for the first floor.
ED
Old 02-04-04, 03:18 PM
pagerboy
Its either a hot water tank or a boiler used for hot water heating.
Heating hot water is useless because its already hot.
Anyway is the HWT electric or gas and are any of the lines insulated?
