Getting a new house, want to install softener but no loop?
Old 08-16-04, 09:40 PM
goldenbuddha
Can I still get one of those water softeners from Home Depot or Lowes? I have found that the new house does not have a soft water loop. Any info would be most helpful.
If I need a "loop" installed, will it be prohibitively expensive? Thanks!
Old 08-17-04, 05:18 AM
G
You need to install a softener before any tee to fixtures where you need softened water, or you get rawhard water there. So if you can't find a place to do that with the existing plumbing, then you need to install a "loop" meaning to cut the service line and run it to the softener and then back to the cut. And from what I hear that can be expensive although it depends on your location and length of the lines etc..
Gary
Quality Water Associates
Old 08-17-04, 07:20 AM
goldenbuddha
water softener
I think I get it. hmm I guess I need to get a plumber to come have a look to be sure. Thank you!
