Lower Salt Settin w/Iron
Old 02-27-05, 12:26 PM
laajr
I just had my water tested and have 1ppm of iron and 65mg/l hardness. I have a 32k capacity system and I was looking at using a lower salt setting to maximize my salt use.
I've read that if you have iron in the water, you should't use the lower salt setting. As it doesn't fully regenerate the resin bed (with the lower setting), eventually the bed will become saturated with iron and lose its'' effectiveness.
Appreciate your input on this subject.
Thanks
Loren
Old 02-28-05, 08:22 AM
G
That's true.
Gary
xxxxxxxxxxxxxxxxxxxxxxxx
Company Name Removed Only
Doug Aleshire, Super Moderator 2
Old 02-28-05, 09:11 PM
laajr
Thanks.....
