another iron bacteria question
linoleum removal
what is the easiest way to remove linoleum without wearing yourself out. i have rented an electric remover, but it is not doing the job.
mike
mike
Our water has high iron, rust and iron bacteria (recent water testing is at the lab. right now), the iron filter seems to gets out the rust and red water, but even with the iron bacteria shouldn't we still have soft water coming from the faucets if the softner is working properly? We question that the new softner resin may be damaged. Iron out has been flushed through it once. I know the iron bacteria has to be killed(I've read volumes on it all) that is our next set of steps after we get the water tests back.
When flushing a water softner with iron out does it clean the resin tank of iron build up or just the controls on top of the unit?
linoleum removal
mike
mike
