Water remaining in water softener tank
Old 01-28-06, 12:31 PM
L
I have a Sears single tank softener (just one tank hold both resin tank and salt / brine). It seems to cycle normally. After cycling I see there is about 2-3 inches of water left in the bottom. Usually this would be covered over with salt but I am very low - time for more salt.
Is it normal for that level of water to remain in the bottom of the tank after cycling?
Thanks
Old 01-28-06, 12:56 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
The water is there to dissolve the salt. I don't see a problem with the water being there. You are correct though, you need to be adding salt or the softener won't work. Good luck.
Old 01-28-06, 03:09 PM
Jay11J's Avatar
The 2-3" is normal, with low salt, you are not going to get the full softness.
If there a lot of "dirt" or inpureity, go ahead and clean it out with a wet vac.
