United Standard Hydro-Quad water system
Hello all, I bought a house that has a Hydro-Quad water system and I cant find anything about how to set it. Could somebody please help???
Well, if it came with the home then you haven't got much of an investment into it.
I wouldn't consider it a very good technology due to its design and equipment.
http://www.udiwater.com/HQdiagram.ivnu
I would not mix carbon and resins in the same tank, let alone a filtration meida as the carbon will start to deminish until it is gone. The filter media may cause the resins to break down until those need to be relaced.
The valve is one of the cheapest on the market made by Fleck. Not bad but not very efficient if it is just a timer-type.
Have your water tested before and after the unit to see if it is working.
Andy Christensen, CWS
