Clear2O charcoal filter/pitcher?
Old 02-02-08, 08:43 AM
Y
Received 24 Upvotes on 23 Posts
This has been advertised a lot lately. A charcoal carbon block in lieu of loose carbon in water pitcher filters.
Ad says over 50 chems removed more than 99%.
I'm dubious. What do you knowledgeable folks think?
Old 02-02-08, 10:32 AM
nap's Avatar
nap
nap is offline
New Member
Received 2 Upvotes on 2 Posts
I nabbed this from a website:
http://www.enviroalternatives.com/watermethods.html
CHARCOAL:
-COMPRESSED CHARCOAL/CARBON BLOCK is the best type of charcoal filter, can remove chemicals and lead, but is easily clogged, so should be used with a sediment prefilter.
-GRANULAR CHARCOAL is cheaper, but water can flow around the granules without being treated.
-POWDERED CHARCOAL is a very fine dust useful for spot cleaning larger bodies of water, but is messy and can pass through some filters and be consumed.
As they state, it is not that loose is any worse in actually filtering but because it is loose fill, the water may not actually be filtered because it may pass around the loose charcoal.
They both provide the same filtering abilities as far as types of contaminants removed, it is just that the block is better because all of the water is forced to be filtered.
Old 02-02-08, 10:33 AM
A
Show us what you are talking about. Who advertising, testing?
Carbon blocks take out more than GAC filters, including VOCs.
Andy Christensen, CWS-II
Old 02-02-08, 10:45 AM
Y
