Kinetico Mdl 60, Not Working
My Kinetico Mdl 60, Is Not Working. I Can Manually
Start The Cycle, With The Manual Setting Screw.
It Will Go Through The Complete Cycle.
I Never Hear It Recycle On Its Own. Which Was What It Was Doing Before.
What Level Should The Water Table Be In The Brine Tank? The Water Is Above The Grid In The Bottom Now.
Where Should The Float Be Set.
The metering pawl may be broken or chipped. It can be a simple replacement if that is the problem.
Where are you located? How old is your machine?
The water level should be approximately one inch above the grid plate. The float setting depends on your wate4r conditions and the number of the disk in the top.
Andy Christensen, CWS-II
