Fleck 5600SE advanced settings (tweaks)
Howdy again, gang:
I've finally gotten a successful Fleck 5600SE installation completed (after bad bypass thread/pipe dope problems resulting in unsweating/resweating fittings, etc.
), and I have some questions about "tweaking" the settings on my 5600SE.
We have "unique" requirements vs. industry standard settings, we have a 32k grain capacity (1.0 cu.ft. Nelsen C-100 resin) 9x48 tank -- however we are only 2 people, and probably use < 50 gal per day/per person. We have no water treatment issues other than 20 gpg hardness (no iron, etc. etc.)
I'm surprised I haven't found a "guide" to making ideal settings using Fleck's "advanced" menu interface (1980's Hewlett-Packard printers come to mind
Anywhoo -- my concern is with the lengths of time used for each stage or step of the regeneration cycle -- for instance, during step 2 "brine fill" -- the Fleck draws water out of the brine tank for about 10 minutes, then the Fleck continues pulling air from in the brine line for the remainder of the (factory default) 60 minutes -- is this correct?
Feel free to scold me for being a newb, perhaps I'm not coming up with valid search terms? I'd like to optimize the settings for each "stage" of the regeneration process, as using the industry-standard calculations, the softener should only regen every
New Member
I like the HP reference
Do you have these master programming instruction sheets?
click here for Fleck 5600SE down flow master programming instruction sheets
You can experiment as much as you like. A prudent step before changing anything would be to record all your current settings so you can do a graceful retreat if necessary.
Thanks for reading my short novel, justalurker, and for yet MORE invaluable feedback -- it's greatly appreciated.
I'm working with my dealer to better understand some of the settings, and I actually have gotten a couple conflicting bits of information, so I have 2 more very general questions:
Fleck 5600SE -- during "Step 2" (brine draw) -- the system draws as much water as it will out of the brine tank within the first 10 minutes, even though the step is set for 60 minutes -- is this correct behavior?
Also, during "Step 4" (brine refill), the brine tank is refilled to nearly 6" of water above the mineral grid (roughly 12" of water in the tank, measured from the very bottom) -- this seems excessive to me and the manuals say to expect water 1" above the grid...
Thanks in advance!
Thanks in advance!
New Member
Once the control valve has sucked all the brine it can from the brine pickup the air check valve in the brine pickup stops the control valve from sucking air.
Each gallon of water sent to the brine tank dissolves 3lbs of salt.
The height (depth?) of the water in the brine tank is determined by the shape of the brine tank.
For example, if your control valve has a 12 lb salt dose then it will put 4 gallons of water in the brine tank but if you have n 11"x11" brine tank the water level will be at one height as opposed to the water height in a 15"x17" brine tank or an 18" diameter round brine tank.
Here's another curve ball, salt in the brine tank displaces water so that effects the height of the water too.
It's an optical confusion.
If your soft water is holding all the way until regeneration and the softener is regenerating every 7 or 8 days and you're not using a mountain of salt everything is working properly.
