kentico "200" and "vx" system
My neighbor lost his home in the lending deal. I bought his water system. It is a Kentico softener with only "200" on the tanks. There is a large pre-filter that I will be installing. My real questions start at the drinking system. Is there a guide/map. as to where all the lines run to and from? I think I have them hooked up the way they came out of his house. He lives right next door, so the city water we both have should be the same and I should have no need to change/add any equipment.
I will need much longer drain lines for the softener and ro unit. Can I get them at Lowe's, or do I have to go to a Kentico dealer? I am planing on changing the pre-filter, do I need to take the whole unit, or just the old filter? again do I HAVE to go to a Kentico dealer to get the filter?
As for the ro unit, the blue indicator was all the way up when I removed the unit, should I replace the 3 filters? and if so how much am I looking at? My local dealer is not the nicest group of people, I have dealt with them before on other business. I don't want to give them any more of my money than I have to. But their two stores are the only ones that came up when I typed in my zip code. I'm in eastern Ohio.
So I have so many questions. A plummer friend is coming over in the morning to help install the unit. Any links to the hose connections would be the biggest help.
I am mounting the unit on to the wall in the utility room right under the sink for easy access. Is this a good idea? I have pictures if they will help.
thanks
Eric
thanks
Eric
What do you mean by 'large' filter? Everything is relative. Can you describe it a bit more? height/width?
thanks
Eric
thanks
Eric
Sounds like a good place to mount it. Are you connecting it to a fridge?
Good luck and you got a deal.
Andy Christensen, CWS-II
current fridge has no icemaker etc
the new one will
Im not going to say which dealer as i might have to deal with them in the future.
I was in his place today and found a bunch of paper work!!!
I added hyperlinks to my photo bucket account. I hope it is not to much info.
it is a drink wtr sys plus vx 01 "model 60" installed on 07-13-2002.
hardness-20
iron-.5
tds-350 it is city water but chlorine and ph were not tested.
the top of the storage tank looks like this
And here is the ro unit on the mountting board i made
my main question is, what line goes where. there are 3 from the tank to the unit, what order do they go in? the manual does not show this. i dont want to screw it up!!!
here is a drawing of how it is hooked up now
here is the way it was tied into the plumbing at his place
the prefilter is a flow-max with blue endcap 20 inches long and says it is reusable, but when i opened it black "gunk" fell out and continues to whenever you tap it on the floor.
here is the pre filter unit
here is the softner tanks 41 inches tall and 27 inches around or 8 inches across they are smooth but you can see the weave of the material used to make them.
here is the bypass unit
here is the tap
the disk on top of the tank is a "2"
here is some writing put on the main tank when it was installed
here is the label on the main tank
here is the brine tank
these are the manuals I found
drinking water system
softener
filter changer
flow-max
to change a filter
safety guide
hardness-20
iron-.5
here is the tap
softener
filter changer
flow-max
to change a filter
safety guide
Thanks,
I will get back with you asap.
I could try to get a manual to you. There are some additional aspects for the RO connection that might influence its productivity.
Thanks you patience.
Andy
Andy
ok good we are installing it tonight or tomorrow moring. he said the three pr lines were hooked up right, but did not understand the "t" in the main line to the RO. Im gonna pick up a new pre filter, he said to take this one to the car was and spray it out, the paper work says you can do that, but for 15 bucks ill just get a new one. he is installing it for free, he owes me a favor, so i only have to pay cost of materials.
just got home from the kentico dealer. they looked up the system and they are the ones that installed it. It has a number 2 disk on top. She said it is a "k60" unit and was/is "top of the line". I got a new 20/20 filter, and wall mount for the unit since we are using "cpvc" to plum it in.
Then we came to the RO unit. I have a vx1. I showed him the diagram I posted here. He said it was all wrong. and finally gave me a "copy of the store diagram" I had to ask 5 times. Here is what they gave me. I re did the unit according to the paper. He said they ont use the "green" port at all anymore. but said since i have it to keep it. is this normal? second, I do not have the "check valve" shown on the line to the union tee. Do I need this? it was not on the other system. There is a part number for it, 8954 should I buy this and install it?
They also had allot of bottles to add to the systems, are these needed?
I guess I will install as is and pay 15 bucks to have them come test the water quality and pressure to make sure I have the right disk. and everything hooked up right.
Let me know what you think
tell me what i can do if anything to make it run better. you said before that there were things you can do to make it more efficient.
It is being installed right now. Wish me luck. I should have pictures tonight
