Help with existing filter system
Professional lab water analysis 7/17/2008
Arsenic, Total <5 ug/L
E. coli <1 MPN/100mL
Chloride, Total 16 mg/L
Copper Total <0.05 mg/L
Iron Total 10 mg/L
Flouride <0.4 mg/L
Hardness by Calculation 20 mg/L
Manganese Total 0.57 mg/L
Sodium Total 12 mg/L
Nitrite-Nitrogen Total <0.2 mg/L
Nitrate-Nitrogen Total <2.0 mg/L
Lead Total <0.010 mg/L
pH electrometric 5.7
Total Coliform Colilert MPN <1 MPN/100ml
my comments:
This is a private well of 180ft drilled in 9/04. Water is clear when first drawn but will turn rusty if left to sit open or heated. Precipitated iron will settle but very slowly, takes longer than a week. We do not have a pool and do not water our lawn. There is a water filter system in place professionally installed that consists of a variable Stenner pump injecting a measured amount of bleach before an 80G pressure tank (Well Mate). This precipitates the iron. Then a filter tank of 2.0 cubic feet of Filter Ag with a backwashing filter head (Water Soft) to remove the precipitated iron. Then to a 2.5 cubic foot tank with a mixture of 2.0 cubic feet of activated carbon and 0.5 cubic feet of calcite to remove the residual Chlorine and to raise the pH. The level of residual chlorine is monitored by sampling the water after the Filter Ag tank and before the carbon/calcite tank, I typically maintain a residual of 1.0 mg/L.
We get a significant amount of precipitated iron that will bleed through the Filter Ag tank, especially at high flow rates. I do not like the fact that the Filter Ag tank backwashes with "dirty" water. I do not like the fact that the pH problem is not addressed before trying to precipitate the iron. I have added a draw off valve at the very bottom of the 80G pressure tank so that I can periodically remove any iron sludge that accumulates in the bottom of the tank. I do not have any confidence in the local person who designed and installed the system and would appreciate any suggestions you may have as to any additional equipment or changes to the system. Some specific questions/ideas that I have:
1. Could I fit a double Stenner head to the pump so that I can inject bleach as well as soda ash to raise the pH at the same time the iron is oxidized? Do those reactions work together?
2. Could I change the Filter Ag tank to a mixture of Filter Ag and calcite to correct the pH at the same time as the precipitated iron is being removed? Does calcite have any filtering properties? Could the filter tank be 100% calcite? Can I filter and correct the pH at the same time?
3. Is 2.0 cubic feet of filtering media sufficient to remove 10 mg/L of iron? Should that tank be bigger?
4. How much activated carbon is needed to remove a chlorine residual of 1.0 mg/L?
Dave
Iron Total 10 mg/L
Flouride <0.4 mg/L
my comments:
Dave
More accurately, you have a retention tank. Pressure tanks have air bladders in them.
You have very challenging water and it can be fixed.
Andy Christensen, CWS-II
Thanks for the reply the information helps a lot
I suppose this is on a timer. If so, how often does it backwash?
Yes it is my understanding that the WaterSoft filter head is just a re-badged Fleck 5600.
Twin tank backwashing filters have the advantage of backwashing with treated water. Kinetico's Macrolite media (engineered ceramic) filters down to 3-5 microns. Fliter ag is between 20 - 30 microns.
They sound interesting, unfortunately the closest dealer is 3 hours away. I'll keep it in mind as I consider my options.
I have never done this but it makes more sense than than mixing carbon and calcite. pH below 6.0 will need a mix of calcite and MagOxide.
What volume and mix ratio would be appropriate?
Do you have any experience with hydropneumatic set-ups, where the iron and manganese is oxidized by injecting air into the incoming water which is then maintained as a large bubble of air in the retention tank. The UT80 Well Mate tank I already have can be converted to this type of tank. Then I could inject soda ash prior to the retention tank to correct the pH, oxidize the iron and manganese in the hydropneumatic tank and then filter with the two tanks I already have. I have no idea whether the UT80 tank is big enough to allow for the complete oxidation. How quick are the soda ash and oxidizing reactions? Not as "clean" a system as the Kinetico because I would still be backwashing with dirty water.
Thanks again for the help.
Dave
Dave
