Kenmore ultrasoft 280 installation help
Old 09-06-08, 05:35 PM
Need Help w/basic steps to start process. The plumbing is in place just need to know what the next step is? I have already setup the time/regeneration time but I'm confused about what to do next (i.e. run water thru system, add salt, sanitize, etc...).
Any help is greatly appreciated.
thanks, Joe
Old 09-06-08, 05:44 PM
biermech's Avatar
Received 3 Upvotes on 3 Posts
Make sure the unit is in a backwash position. Open the bypass valve slowly and let the unit fill. Once you get a steady stream of water to the drain, open the bypass fully. Add some water to the brine tank. Maybe 2 gallons. Add your salt and enjoy the soft water.
Old 09-06-08, 05:53 PM
Thanks for your input will give it a try.
