Ecosystem Sensa-a-tronic softner help
I was having problems with my water softener not closing a valve after regenerating. I took the head unit off and took it to my bench to have a closer look. I found two of the plungers were not moving freely so I removed them and cleane them up. I put everything back together with some new o-rings and things seem to be tight and not leaking. The problem I have ran into is that when I put the unit back together and plugged it back in the unit displays 3.1 then clears the screen and the word model is light on the top of the display and just lines go through the large numbers in the middle of the screen. The unit was in the house when I bought it and I do not have a manual so I just have tried to push buttons but all I get is blinking dashes. Can anyone tell me how to reset the unit or enter a model number if that is what it is looking for? Thank You!
