R/O system location
R/O system location
I plan on putting in an RO system when I get a softener.
I don't want it located under my sink in the kitchen cabinet because I don't want to hear it dribbling all the time.
I know I can install it in my basement and hang the system off the basement ceiling beams/joists.
But I was wondering where the best location would be.
One company said over by the the floor drain where the softener is going to be, but that is a good 15-20 feet away from the corresponding kitchen sink location in the basement.
Another guy said he would put it as close as possible to the location of the kitchen sink - of course then it's pretty far away from the floor drain.
So which is it? It makes sense to me to keep it as close as possible to the sink to help with the pressure of the system.
Will there be any problem w/ a 15-20-25 foot run of the rejected water to the floor drain?
thanks
--Dusty
thanks
--Dusty
As biermech said that should be no problem. It is probably a 1/4 line. Further than 30 ft I would enlarge the line to 3/8" with a simple john-guest fitting. There will be some resistence but not a greeat issue.
Andy Christensen, CWS-II
