New water softener install questions
Hey there,
I just finished all the plumbing yesterday for my new water softener and everything looks good. I have a new unit with an Erie controller that I managed to pick up for cost from a plumbing contractor my Dad deals with. Since the unit is intended for contractors it doesn't come with detailed instructions on install and setup and I don't really know how to start up the system so it can start working.
So here's what happened when I tried on my own.
Once all the plumbing was completed I connected the small hose from the resin tank to the brine tank and added a bag of salt to the brine tank. Turned the water back on and opened the bypass valves. Not sure what to do next so I toggled through the electronic controller until it said "Regenerate in 5sec" and waited. Moments later water came shooting out with force through the top of the valve where it's indicated "drain"
So what did I do wrong? Why would water shoot out of a drain valve with so much force?
What are the steps I should take to start up the system properly?
