low water pressure ultrasoft 200
I have almost no water pressure with my softner, its fine on by-pass, it is going thru re-charge cycle because i heard it last night, the venturi is clean, the softner is 6 years old it is a ultrasoft 200, i noticed the water hasn't been as soft as it used to be for the past few months it also hasn't been using any salt, please help.,
What are your water conditions? Gives as much detail as possible.
Sounds like your salt has bridged and the softener went through numerous regenerations without working. Depending on your water conditions, the resins may have been damaged and the media may be clumping up restricting pressure.
Can you see water in the brine drum?
Andy Christensen, CWS-II
