Which water softener
I have had my water tested by lots of people latley
3.5 ppm hardness
2.3 ppm iron
I want soft water and to get rid of that red stuff all over my appliances.
Rainsoft 3490 total system filter and softner to high for me
a hydro injection system with multistage filtering tank for iron and sulfur for 1850 doiable
and a pelican for 1300 no salt softener with one tank for softening and another for filtering iron and sulfer. Water boss shelf system with a softener and filter.
Any help please
3.5 ppm hardness
2.3 ppm iron
Any help please
The Pelican is NOT a softener and will NOT remove iron. This one will not help you that way.
A water softener will remove the iron from the water. You do have to keep the resin clean of the iron. That can be done with the use of salt with Iron out in it. Should cost around $600.00-$800.00
ok
iron 1.3 ppm
hardnes 5 grains
tds-112ppm
ph 6.5 s.u.
4.5 gal/36 seconds or 7.5 gpm
3adults 1 child
some sulfer during sommer not real bad but any is bad enough
this is what im looking at right now
COMPLETE FLECK2510SE 32,000 GRAIN ON-DEMAND WATER SOFTENER
SYSTEM
THIS COMPLETE FLECK 7000 1.0 PYROLOX FILTER COMES
this will run me around 1200 + install local plummer quoted me 300 to 500 install for both. any help would be great
thanks in advanced
iron 1.3 ppm
hardnes 5 grains
tds-112ppm
ph 6.5 s.u.
3adults 1 child
SYSTEM
thanks in advanced
