Rainsoft water softener
Old 02-06-09, 06:53 PM
Question Rainsoft water softener
I have an older rainsoft water softener that recently broke the shear pin connecting the drive motor to the cams that actuate the valves. I am trying to find information concerning where the cams should be relative to the timing wheel. If anybody has some information or pictures, I would appreciate it.
Old 03-10-09, 12:14 PM
T
You probably already have your shear pin fixed but if not, I had the same problem, several times. I think I still have some pictures if you need them and also so you know, a 1/8" welding rod with the flak knocked off and cut to size works just fine.........and a lot cheaper.
