Kinetico 2060s Discharges ALWAYS!
I have a 2 year old Kinetico 2060s. When the tab indicator over the disk is in the 6 O'Clock position, water drains out of the discharge ALL OF THE TIME! However, when the indicator is in the 12 O'Clock position, it is fine. Is this problem just a bad seal or something?? I have torn into a model 60 head before, and it was not a big deal. If you think it is just a seal, I don't have any reservation in going into the head to repair.
Please advise...
Please advise...
Most likekly it is a piston and would need to be replaced. While it is apart, other parts such as seals are usually replaced or lubricated as well.
I assume you are on well water, right? How old is it?
Andy Christensen, CWS-II
