water softener not recharging automatically
My "Water Care" Sensial Meter water softener does not recharge automatically. It WILL recharge manually (and softens nicely), but has recently ceased to do it on its own... HELP!
What you have is a Fleck 5600 metered demand unit sold by Water Care. The is a cable that comes out of the back of the valve and connects to a dome (meter assemble). Make sure the cable is in place. If it is, twist a bread tie on the cable. Pull the bread tie straight out (use as a pointer) and note where it is. Run water in the house. If the pointer moves (bread tie), the meter is working and the problem is else where. If not, replace the meter dome. Here is a link for the manual.
http://www.pentairwatertreatment.com...al%2042447.pdf
