Kinetico Supra K44 Problem
I have a Kinetico Supra K44 that does not seem to be regenerating. The water feels hard and there is plenty of salt in the brine tank. Is there a way I can manually cause it to regenerate to evaluate the regen function? I see a phillips head screw on the top of the rotor assembly. I can move it so an internal tab moves to different functions, but nothing seems to happen.
The phillips slot is the actuator. It has a tab that is visable. By pushing down while turning clockwise, it should contact the control disc (it has a notch that is visable but you have to look close)and start a regen. If not, try to feel if it is "slipping" on the control disc. If the control disc does turn and regen has not started, make sure unit is not in bypass.
I was able to manually regenerate the system. I did each side twice and it seemed to work fine. I could feel the water flowing throught the brine tube and could see the water coming out of the drain line. I just don't think it is softening the water. I pulled the brine tube out of the tank and everything looks OK there. Could it be the resin beds need to be changed out?
That depends if the water has chlorine. Chlorine will degrade the resin over time. If you have iron, it just may need a cleaning with iron out. How old is the unit?
