Fleck 9000 repair
does anyone know the procedure in changing the pistons or a site that explains the procedure
Heres a manual if you didn't have. one.http://www.pentairwatertreatment.com...al%2040944.pdf
They may be a little hard to replace without the tool but can be done. Make sure you put them in order...seal, spacer, seal..etc.
fleck 9000
Thanks for the link, I was hoping to finds some step by step instructions on replaceing the pistons. What is the tool that you mentioned that I might need. Thanks again in advance.
The tool holds a basket and seal and I believe it's called a stuffer. I believe it's possible to drop a basket into the tank while installing. The stuffer prevents this. Without it, be careful. I don't know of and written instructions for this.
