kinetico k30'20 water runs out drain all the time, no suction in float water
kinetico k30'20 no suction,top wheel wont spin,water runs to drain in all cycle
hi 1st timer.... I have a k3020 kinetico. the serial# on one of the 2 tanks says 321366. they are tan.
Problem. I dont notice the top wheel moving at all. it seems to stay in one spot. also when I push down with a screwdriver to regen it, no matter what cycle its in water constantly flows from the tube going to my drain. also I took all the salt out of the big container/cleaned all the crap and just filled it about 4 inches above the base and turned on. the water level stays the same. nothing makes it raise or lower. A year ago gorden bros replaced the float, k-30 hy cup, control disk, repaired gearlog level 1, checked metering, cleaned valves......................................... now it has the above 3 problems... any help would be great...thanks
Andy Christensen, CWS-II
