Well Water pH
Well Water pH
My untreated well water has a pH of 6.4. I am using a neutralizer that brings the pH up to 7.0 but it leaves a thin lime deposit on the fixtures. I would like to use the water directly out of the well without the neutralizer but I am concerned that the water will eat the pipes. Is a pH of 6.4 too low to use with copper piping without treatment? Thanks.
Generally acid water such as your will gradually erode copper. The aggressiveness will depend upon other parameters of your water such as the level of disolved solids.
Do you get any blue/green coloration on any fixtures, tubs or shower walls or does the water have a blue green cast in a bucket or tub? If you do that is copper that has leached into the water. If the pipes are being eroded you will develop pin hole leaks at some point--how long depends on the aggressiveness of the water and on the thickness of your copper pipes which is indicated by the grade--M being the thinest, L a middle grade, and K the heaviest.
The problem with deposits caused by the AN filter can be readily treated with a softener.
What is your hardness before and after the filter? I am guessing it is relatively low (below 10 gpg?). Try to find out the TDS, too.
Andy Christensen, CWS-II
Thanks for the quick replies. I have been using the AN system since we moved into this house 14 years ago so I have never seen the blue-green problem. I am thinking about upgrading my bathrooms, and this is what is causing me to act now. It sounds like I need to get my water tested and talk to an installer here locally. I tested my pH using a kit I picked up at a pet store. Again, thanks for the replies, you helped me a lot.
