Kenmore Ultrasoft 800 softener tank will not drain
We had a Sears extended warranty on it and they sent a technician who ran through some diagnostics, checked the venturi/gaskets etc and said the problem was that the drain line was clogged. (The original installer ran the drain tube into a T in the crawl space). He also demonstrated that the unit will drain fine into the yard.
We then had a plumber in to check the drain and he said its clear but could not help us with the softener.
Any recommendations on next steps will be greatly appreciated.
A blocked or restricted drain will cause the unit not to draw the brine water. If the Sears man ran the drain into the yard and it drew the brine water, but does not draw when hooked to the drain, there is something slowing the flow to the drain. Did the Sears man use the drain line or did he provide his own? A common problem is blockage at the drain flow controller.
Where would the drain flow controller be? (Our drain line is semitransparent poly tube).
The drain flow control is located in the elbow that the drain line attaches to. Simply pull the clip the holds the elbow to the valve and remove. The flow control is struck in the end of the elbow. Also, the drain can not be run more than 8' above the drain elbow or it will not draw brine. Keep me posted.
Should I be able to blow air into the drain with my mouth and not have it feel as if there is a blockage or is that an invalid test?
Thanks for the guidance so far.
