RO & Rotten Egg Smell
Hello,
I have had a whole house RO system installed alittle less then 2 years ago. The resale outfit told me that the membrane did not need to be replaced for up to 5 years. Almost at the two year mark I insisted in replacing it and just got around to doing it. When I removed the membrane cartrige the water inside smelled like rotten eggs. Should I be concerned that perhaps we were drinking this water for some time now? The taste or smell of the water after post filter was not there however the taste has started to be different over the past several months.
Agin what does the rotten egss smell mean and should I be concerened? Add any recommendations you may have....
Thanks
JC
Thanks
JC
The rotten egg smell is from sulfur bacteria. It is harmless other than the foul order. If you are on a private well you can shock it with chlorine, but if it is not getting to the water in the house you could just leave it.
Ok
Ok that makes sense. I am not on a well just have an RO hooked up to public water. So by purging out the system will it remove the bacteria or do I need to add clorine to the line?
