Advice on how to treat water
I own a rental house with a domestic well. The tenant says appliances and clothes are getting a yellow stain. I assume that is from the iron. Is there a softener or filter that is low maintenance that will work? Of course I was hoping not to spend a bunch of money on this.
Here are some of the results of a water test:
Iron 1220 ug/l
Manganese 730 ug/l
pH 7.6
total hardness 613 mg/l
I have a detailed test if this is not sufficient.
Thanks
Jason
Iron 1220 ug/l
Manganese 730 ug/l
pH 7.6
Thanks
Jason
With hardness that high, I would think you would want a softener to protect your water using applicances (pipes). Of coarse with a softener, the maintainance is adding salt. If you just want to remove the iron, BIRM (Best Iron Removal Media) is a good choice. It has no maintainance so to speak (no salt).
3 bedroom house with about 20gpm from well.
Thanks
Result Units
Total Hardness 613 mg/L
Calcium 117 mg/L
magnesium 78 mg/L
Potassium 1 mg/L
Sodium 136 mg/L
total Cations 18.2 meq/L
Boron 0.4 mg/L
Copper ND ug/L
Iron 1220 ug/L
Manganese 730 ug/L
Zinc 450 ug/L
total Alkalinity 160 mg/L
(as CaCO3)
Hydroxide ND mg/L
Carbonate ND mg/L
Bicarbonate 190 mg/L
Sulfate ND mg/L
Chloride 600 mg/L
Nitrate ND mg/L
Nitrite as N ND mg/L
Fluoride ND mg/L
Total anions 20 meq/L
pH 7.6
Specific Conductance 2110 umhos/cm
Total Dissolved Solids 1300 mg/L
MBAS(foaming agents) ND mg/L
Aggressiveness index 12.3
Langlier Index(20C) 0.4
Thanks
Result Units
Calcium 117 mg/L
magnesium 78 mg/L
Potassium 1 mg/L
Sodium 136 mg/L
Boron 0.4 mg/L
Copper ND ug/L
Iron 1220 ug/L
Manganese 730 ug/L
Zinc 450 ug/L
(as CaCO3)
Hydroxide ND mg/L
Carbonate ND mg/L
Sulfate ND mg/L
Chloride 600 mg/L
Nitrate ND mg/L
Fluoride ND mg/L
pH 7.6
A 1.5 Cubic Foot softener will work good for the 2 people. You may even want to go with a 2 CF so if other folks move in with more people. I use a Fleck 5600 meter demand system. You should be able to purchase it for around $600.00.
