Water softeners and septic systems.
Old 04-07-10, 01:41 PM
W
I'm cutting in a SW loop for a salt/resin softener and wasn't sure if the discharge was safe for my septic system.
I live in Las Vegas, NV and the city water is pretty hard (dissolved minerals). Is there another type of system that's a better alternative? House has 4 bathrooms.
Thank you for any advice.
Old 04-07-10, 01:54 PM
Akpsdvan's Avatar
Received 9 Upvotes on 9 Posts
City water and private septic?
Hardness? number of people?
http://treatmenttech.net/site/reside...eptic-systems/
Old 04-07-10, 10:43 PM
W
Yes, city water and private septic.
Water is reported at 275ppm/16 grains per gallon, and there are 6 of us in the house.
Great link. Thank you.
Old 04-07-10, 10:54 PM
Akpsdvan's Avatar
It is information .. information is good..
With 16grains, and 6 people , my formula has 1.5 cubic cleaning about every 5-6 days at 9lbs each time or about 58lbs of salt per month..
Others might have different numbers or say different... but this gives an idea as to what you might see in usage..
Old 04-08-10, 05:02 PM
W
Thanks for the estimation calc. I can deal with 60lbs a month.
Any particular features I should be looking for in a softener?
Old 04-08-10, 05:27 PM
Akpsdvan's Avatar
Metered would be at the head of the list..
There is the older style of meter and then there is the elect or digital metered units.
I like the ones that have the media tank outside the brine tank, that way if some thing happens to one or one goes to clean out the brine tank the other part does not have to be moved.
Some like Clack valves, Some like Fleck valves..
I have used Fleck for 20 years and like them and have no plans of changing..
I like the item called a turbolator where the media or resin is changed over each time it cleans and there is often more in the same size tank ..
Some will say that the turbo cuts down a bit on the flow rate or pressure, I have yet to see it in the ones that I have put out over the years..
If you wanted to cut the salt down by 10lbs per month... give or take a little, a twin would do that because the twin would run closer to the full capacity of each tank before changing to the other tank.
Those are some ideas to think over.
Old 04-15-10, 10:48 PM
W
This turned into a good sized project. First off, thanks to Akpsdvan for a whole lot of advice and encouragement. I didn't follow all his advice(bought the GE softener), but I have a much greater knowledge of how these systems work because of it. He really knows his stuff. Thanks man!
I finished framing this little enclosure for the system today.
Got the softener set and all plumbed up this afternoon.
Framed the roof this evening.
All closed up.
Open for salt refill.
Still have to roof it, run a permanent drain line, pull power, stucco, and paint. The hard part's over.
