Need help with settings for Technetic Plus 1000i water softener
Old 02-18-11, 09:23 PM
Hi,
I have had the Technetic Plus 1000i water softener more than 8 years and recently replaced the resin. I'm not sure the settings are correct or not because I have not seen or heard the water softener regenerated. The settings now are as below:
TIME OF DAY (P1) - PRESENT TIME
REGENERATION (P2) - 2:00AM
HARDNESS OF WATER (P3) - 10
SALT AMOUNT (P4) - 6 LBS
CAPACITY (P5) - 1.0 KILOGRAINS/22.6
Does anyone know the settings for Technetics Plus 1000i water softener? Your help is greatly appreciated.
Thanks,
Jonathan Vu
Old 02-19-11, 01:32 PM
biermech's Avatar
Received 2 Votes on 2 Posts
Your settings sound right. Here is a link for the manual if you need it.
http://www.h2otogo.net/pdfs/Techneti...nual_31704.pdf
Old 02-19-11, 03:32 PM
Thank for your help. BTW, how can I tell if the water softener is regererated automatically? Do I have to regenerate it manually?
Thanks,
Jonathan
Old 02-19-11, 07:22 PM
biermech's Avatar
That unit will regen on demand. The more water you use, the more often it will regen.
Old 02-20-11, 12:07 PM
Thanks very much for your help.
