Hague Water Max - Control Panel message "Pause"
Old 03-13-11, 04:00 PM
D
Water Max, model 13beq. The control panel is displaying "Pause". The only way to get it off of pause is to unplug the control panel. Once I plug it back in the system starts the regeneration process and it seems to work. What is wrong with the system?
Old 03-13-11, 04:07 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
How old is the system?
Which control is in use now?
If it is the newer board that could be it or the gray wheel with the earth magnet.
Old 03-13-11, 04:21 PM
D
It is 8 years old, it has the 5 button control panel.
Old 03-13-11, 04:43 PM
Akpsdvan's Avatar
Are you able to do any thing else with the 5 button control? set the time , the number of people or the hardness?
Old 03-13-11, 04:55 PM
D
Not when it says "Pause". Have not tried once I re-plug it since it seems to work until the next regeneration and that is when it will go to pause.
Old 03-13-11, 05:57 PM
Akpsdvan's Avatar
How long does it stay in pause?
Could be that the control needs to be replaced.
