R/O reverse osmosis machine help
about a year ago I got a reverse osmosis machine I hooked it worked for about a month and then it stopped working I tried to be pressurize tank I've tried to let it fill up for days at a time nothing works. Could someone help me with this?
If it worked for a month and then stopped I would first check to make sure water is getting to the unit (is there a shutoff valve turned off somewhere). Next I would check for clogged filters or clogged water line. It also would not hurt if you told us what make and model RO system you have.
