clack valve problem
clack valve problem
My Clack Valve ws1 does not count down the gallons usage. It stays at 2400 gallons and does not count down when water is running...help!
When water is flowing there should be an icon flashing, if there is no icon flashing when water in the house is flowing then you will need to check the meter turbin and make sure that there is not some thing holding it in away for it not to turn.
This will need the use of your manual.
