Watts AF- 40K Premier water, no leftover water in brine tank
Old 09-21-14, 02:26 PM
P
Hi,
I recently bought a new AF-40k from Costco. I had someone install it for me. What I noticed that it doesn't leave water in the brine tank to form brine.
When I run regenerate, I can see that tank gets filled with water, but afterwards, the water is all gone again and it's dry.
Any ideas what's wrong? I would like to avoid having a plumber come and charge for two hours for this.
Thanks a lot.
Old 09-21-14, 11:04 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
Sounds like yours is like the sears or ge unit, fills the salt tank first and then draws out the water over a 90 minute time frame.
If you start a regen and watch the system put water into the salt tank and then take it out , then that is the type of system you have and that is normal for it.
