question on reverse osmosis system
Old 10-01-14, 06:11 PM
I have a reverse osmosis system under my kitchen sink. I want to put a t quick connect in and run a line to my ice maker on my frigerator. There about 10' max apart and max 2' in elevation difference between them.
Question is, can I do this and will the ice maker get the water it needs?
The line on the system is 3/8" should I run 3/8" line to half way then go to the existing 1/4" line that goes into the fridge? Or should I get a t with a 1/4 outlet and run just a 1/4 to the fridge ?
Thanks
Old 10-01-14, 06:19 PM
lawrosa's Avatar
Super Moderator
Received 59 Votes on 51 Posts
Run 3/8" all the way to the fridge....
Old 10-02-14, 09:37 PM
O
Received 1 Vote on 1 Post
As lawrosa said, run all 3/8". If you can, cut as much of the 1/4" from the fridge so the 3/8" is as close as possible to the actual fridge inlet(s).
Old 10-03-14, 07:11 PM
Ok thanks guys. That was my plan. Just got a 3/8 t and the 3/8 with a 3/8 to 1/4 fitting.
