Help with Water Softener/Filter /RO unit purchase
Old 10-08-14, 12:24 PM
E
I am in the market for a new water system for my house. I recently purchased a home and the water smells bad and my wife and I will not drink it. I have done a water test and the results are as follows.
Hard water 29 GPG
High chlorine level
no iron
PH 7
I had a Culligan guy quote me 4,500.00 dollars for a system and I am not about to pay that. I am an Engineer by trade and can install the system myself.
What I am looking for and have done some research on is a 40,000 grain softener, a whole house carbon filter and a R/O system for under the sink.
My results lead me to believe my best bet for the money would be a Fleck softener (donít know which to get yet), not sure on the carbon based filter yet and an Ispring R/O system for $190.00.
Can anyone give me some advice on what I should get or not get?
Old 10-08-14, 02:19 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
Softener I can see as well as a carbon system.
RO.. I would question and say wait till after the rest of the equipment to see if more treatment is needed.
Flow rate is some thing that needs to be taken into account. Number of bathrooms, bedrooms... number of people in the house.
A twin softener might be better.
A 1.5 cubic or 48K max
So there are some questions to answer and we should be able to get you closer to what will serve you now and in the future.
Old 10-09-14, 11:52 AM
E
Thanks for the reply.
My house has 3 bathrooms, 3 people, and my heat is a boiler system
I have reached out to a vendor and they recommened the below. Does this sound like a good set up given my probelms?
Fleck 5600SXT Electronic Timer Auto Backwash Carbon Filter 1.5
10x54 Vortech Resin Tank (Almond)
1.5 cubic feet of Carbon
5 gpm service flow rate
3.5 gpm backwash flow rate
3/4 Inch Noryl Yoke with Noryl Bypass Valve
Fleck 5600SXT Electronic Metered On Demand Control Valve Water Softener 48,000 Grain Capacity
Distributor Tube w/Top Basket
1.5 cubic feet of Purolite SST60 Resin
12 gpm service flow rate
2.5 gpm backwash flow rate
15x17x36 Rect Brine Tank w/Salt Grid & 2310 Float Assembly
I am also thinking of buying the Isprings R/O system on Amazon
THANKS FOR THE KNOWLEDGE AND HELP!!!!!!
