Fleck 6700XTR - Could My Programming Be Lost?
Old 10-20-14, 07:48 AM
Post Fleck 6700XTR - Could My Programming Be Lost?
Had this system installed in April and it is our 1st water softener. After a number of problems our plumber finally got it working in August. It developed a salt bridge & I removed salt pellets on top to water line (about 1 month ago or so). It has not gone down since. The Diagnostic mode shows that it has been 496 hrs since regeneration. I am doing a manual regeneration now. In late September we had an electrical problem & power was off for over 24 hours. The manual says it can hold programming up to 12 hours. I was wondering if during that time we lost our original programming. How can I tell? There are only 2 of us in home so we don't use a lot of water, but this seems like a long time to go until a regeneration. Last time, to get it programmed correctly, our plumber had to be on phone with the Fleck distributor to get it programmed. Not sure what to do.
Old 10-20-14, 05:01 PM
biermech's Avatar
Received 2 Votes on 2 Posts
The size of the system as well as the hardness is need to determine whether 20 days between regens is too much or not. A system with 64,000 grains of removal with only 1000 grains per day removed can go 64 days. Post the size of your system and the hardness & I'll be able to tell you what the nubers should be.
