Newbie here needing some water filtration advice....
Old 10-26-14, 12:55 PM
P
Hello all...Looking for some advice from the pros here. I moved into my home about 10 years ago and had installed a sulfur system about 8 yrs ago. My present system is inconsistent since it seems to be getting constant sulfur bleed through.
I have been reading and researching along with being visitied by a few local water companies giving me their resolutions to my issues. Everyone seems to do something diffrent...
Existing System:
Avantapure system (Plastic cover w Avantapure label)
autotrol valve
Prylox bed
Chlorine backwashing nightly
Have not done an official water test at a lab yet
Here are the results of one of the local water companies
PH-7
Iron-1
Sulfur-4
TDS-220
Here are a few of their products:
SYSTEM#1- local water company-over 30 yrs exp professional
IronBreaker-3 airation tank w peroxide injection if needed
New tank- fleck valve-5 yr warranty
Catalytic carbon media
stenner pump if needed-2 yr warranty
checmical solution tank
inline sediment filter to make it easier to chlorinate house pipes
$1895 for ironbreaker , 800 for stenner pump , 99 sediment filter
SYSTEM#2-Local Water company - Water plant operaator w over 30 yrs exp
Rebed existing tank w catalytic carbon and transform system to chlorine retention system
stenner clorine injection pump
retention contact tank
sediment filter
cleaning of home pipes
$2400
SYSTEM#3-US WATER SYSTEMS-Internet based company
Fusion OXi-Gen Whole House Backwashing Filter For Iron And Sulfur Removal
New Tank-lifetime warranty
controller they designed to be half fleck/clack-7 yr warranty
catalytic carbon
stenner pump for peroxide injection- 2yr warranty
sediment filter
chemical solution tank
$1995 for 15 gpm system
$2 for delivery
Any professional advice and opinions would grealty be appreciated...
Thanks in advance
Old 10-26-14, 04:44 PM
biermech's Avatar
Received 2 Votes on 2 Posts
My vote would be chemical injection (chlorine), 120 gallon retention tank, 2 CF Carbon. You must over come the sulfer with the chlorine injection. Once done, you will not have smell. Then use carbon to remove the chlorine. I have seen many different media fail at removing high sulfur. Mostly due to the weight of the media combined with the lack of proper flow rate of the well to backwash the media. Carbon is light weight so no worries of enough flow rate from well.
Old 10-26-14, 05:27 PM
P
Thanks Biermech. I am pretty sure that the chlorine injection would work as well. Here are some concerns;
120 gal retention tanks needs to go in garage adjacent to the room in which the water filter is. Not sure if this would be a good idea?
Chlorine from what I hear is rough to maintain. Crystallization from what I hear is a major culprit. What's the best way to maintain?
Since my tank and autotrol valve are already 6+ years old does it make sense to reuse?
Media that he would use is catalytic carbon. What about this new media called Katalox light?
Old 10-27-14, 04:21 AM
biermech's Avatar
Chlorine is not hard to maintain. The crystallization most likely is the hardness around the injector which may have to be cleaned every 2-3 years. That's hard to say if you should reuse your equipment because I can not see what shape it's in. Katalox media is new to the market. I have sold it twice but have not had the expierence enough to comment on it.
