Lots of bubbles in our drinking water
Old 11-23-14, 08:50 AM
Y
Received 11 Votes on 11 Posts
This has been going on for a month or more. Will explain circumstances later.
Thousands of tiny air bubbles in a glass of water out of the kitchen faucet. They go away in 20 minutes or so....except some cling to the side and bottom of the clear glass I use.
A month ago we came back home after a week away in the RV. I had shut off the incoming house water via the ball valve by the pressure tank. I opened it up a bit (better to do it slowly) and went inside. Forgot to open it up all the way
That night I heard the water treatment system going on. It sounded a little different than usual. I went into garage and saw pressure gauges close to zero and opened up the water supply valve all the way. Gauges went up to normal, around 40-50#.
Bubbles in water started next morning.
We have a BigBlue first in line. Followed by a calcite tank. Then a BIRM iron removal tank. Last is a water softener.
Probably the air will dissipate over time but is there some kind of air relief valve or other way for me to bleed air out?
Thanks
Old 11-23-14, 09:57 AM
Norm201's Avatar
Received 189 Votes on 171 Posts
Are the air bubbles a problem? To me its a sign of highly oxenginated water and that I think is a good thing. My faucets with aerators do that all the time. Maybe not to the degree you explain but I never considered it a problem.
Old 11-23-14, 10:45 AM
Y
Hi Norm....not a problem to me. Better Half is a tiny bit worried. The bubbles show up with the faucet on normal stream or aerated. I am curious as it showed up after my boo-boo. Not seen before.
Old 11-23-14, 11:13 AM
Norm201's Avatar
It will probably dissipate over time or at least reduce to just a little bit. Sometime when the town does a flushing or repair work I'll get it more often.
