Hard Water - questions
Old 02-14-15, 02:25 PM
1. Does hard water cause calcium buildup in "copper" pipes? I read somewhere that it's only true with galvanized (steel) pipes which were used in homes long ago.
2. If copper pipes are clogged, is it possible to "descale" this build up if so how? What kind of treatment. does anyone ever do this routinely?
3. Does a water softener help "descale" pipes?
Old 02-14-15, 02:34 PM
What makes you think your pipes are clogged?
Had the water tested to see what type treatment it needs?
Old 02-14-15, 03:17 PM
Just asking, good to know these things.
Old 02-15-15, 06:13 AM
biermech's Avatar
Received 1 Vote on 1 Post
I have a piece of 1" copper pipe (great sales tool) that is so scaled up you can not stick a pen through it. So yes, scale will build up in copper pipe. There are companies that descale the pipes using chemicales
Old 03-15-15, 12:14 PM
Beutler's Avatar
1. Yes, it certainly does, the longer the exposure the more scale buildup.
2. There are commercial descalers available, but see 3 below.
3. Yes, once you install a water softener and soft water flows over the scale it will slowly disappear.
