Kinetico 2060s OD regeneration questions
- Can someone explain the regeneration sequence on this twin tank equipment?
- It has a #4 disc; how many gallons to trigger regeneration and how many used during regeneration.
- Does this system uses both tanks at the same time while softening?
Many thanks
Many thanks
I have a spec sheet but it does not say the gallons between regen or gallons to drain during regen. I was always under the impression Kinetico's run one tank at a time but from the spec sheet it appears the OD run both tanks together. If you would like a copy, I will PM you.
There is some good info about Kinetico's in general at watersoftenersuperstore.com
