Softener wont draw brine
Old 03-08-18, 06:55 PM
I have an autotrol 155 and its not drawing brine. Removed the injector and filter which was plugged of rust. Still nothing. The tank does fill with water so the line is ok. Cam is fine. The ball in the aircheck never drops either. What do I check now?
Old 03-11-18, 07:00 PM
Akpsdvan's Avatar
Do you have the manual for the valve?
If the injector is clear make sure that the hole that it sets in is clear.
Also could be that the flappers for the brine might not be sealing or opening correctly.
