Water Softener Maintenance
Hi!
I rent a softener. They send out a little postcard once a year to schedule annual maintenance on the softener.
The last time, the service tech and I were talking and he basically said that the service is overkill on a rented softener-- that I would know if there was a problem and, since its rented, they would replace the unit if it got to that point.
Is this true? Do we really only have a problem if we 'have a problem'? (ie: nothing catastrophic would occur all of a sudden-- we would first see, for example, an uptick in hardness?)
Debating on that annual service
Thanks for the replies!
the maintenance is usually taking apart the (klack? Electronic valve) valve, cleaning out the orificaces. Also using citric acid to clean something in the tank
i could do it myself, or they helpfully offer to service it for $150
The only maintenance that would really be a benefit would be to regularly use an all purpose resin cleaner and to occasionally empty and clean the brine tank.
The salt that you add to the brine tank removes minerals that are attracted to the resin but there can be a build up on the resin that salt can not remove.
Regular use of a cleaner can remove rust and other contaminates that attach themselves to the resin.
All you do is add it to the brine tank with the salt and it does its work at the next regeneration.
Here is one type but there are other choices out there.
