Kinetico Q237 - one tank drawing too much brine
Old 12-01-18, 08:51 AM
I have a Kinetico Q237 softener, and I've noticed some very inconsistent softening. I watched each tank recharge, and through the brine well tube, the secondary tank seems to draw out the correct amount of brine, and fill up the tank with the correct amount of water. As I watched the main tank recharge, I noticed that it kept drawing out more and more brine as the regen cycle continued, even into the backwash stage. This is causing excessive salt usage since it's drawing out too much brine and refilling with more fresh water than it should.
Does anyone have an idea as to why only one tank's regen cycle would be having this issue?
Thanks,
Anthony
Old 12-04-18, 06:57 PM
Akpsdvan's Avatar
It could be that one is not pulling enough brine.
Has there been salty taste in the water at any time?
Has there been a lack of soft water?
Old 12-27-18, 07:12 AM
Thanks for the reply. Just for a bit of a back story, I bought this softener used from someone. I've had some small leaks from the brine tubing that I've fixed over time. I ended up taking apart the shark bite fitting that connects the tubing to the brine valve assembly. The tubing had several bite marks in it, so I cut off about an inch of the tubing, plus put some silicone on the o-rings within the shark bite fitting. After doing this, my issue seems to be gone. It must have kept a good seal under pressure, but during suction was leaking air. That's my best guess, because no water was leaking when this problem was occurring.
